July 12, 2019, 09:13 |
Ignition delay
Salvo Miccichè
Good morning everyone,
I am dealing with a methane engine, homogeneous fuel distribution, simulating the ignition and combustion phase (630 deg - 760 deg). Mixture is poor, lambda = 1.5529. I am trying to create a suitable model, so trying pressure and apparent heat release to match with experimental data. My problem is that the pressure (and consequently AHR) raises too late, and reaches low peak values with respect to experimental case. I think the problem is in the Laminar flame speed. My questions are: 1. is it correct to use Gülder correlation in case of methane with lambda = 1.5529? Should I change any coefficient of the model? Can the problem be caused by settings in ISSIM ignition model? 2. is there a way to plot laminar flame speed as a function of crank angle in STAR-CD? My setup: ECFM-3Z (ISSIM ignition with 0.1 J energy) CH4 fuel premixed Adiabatic BC for the electrodes p.jpg ahr.jpg Thank you in advance, Salvo |
October 22, 2019, 15:14 |
Rep Power: 6 |
Have you in the meantime resolved the issue you describe here?
Combustion Simulation ANSYS Fluent - There is no ignition delay | Rudolf Diesel | FLUENT | 1 | May 21, 2023 06:30 |
RCCI model ignition delay | Gaurav0990 | CONVERGE | 3 | July 23, 2021 00:50 |
Combustion Simulation ANSYS Fluent - There is no ignition delay | Rudolf Diesel | FLUENT | 2 | October 1, 2018 01:16 |
Need ignition delay and reaction rate data | ankitraut27 | CONVERGE | 1 | November 7, 2017 15:28 |
Ignition modeling | Julie Polyakh | Siemens | 0 | May 20, 2004 08:05 |
