April 4, 2018, 15:36 |
error during trim process
Can
Rep Power: 13 |
hi guys,
this is not my first model preparation in es-ice and saw a lot of error about it. but this one is new and ı have no idea about this. if someone saw this error or have an idea about it, please help me. thank you. Error: 27600 parents were written to the file "D:\04-Working_folder\04-Star-CD\180304\xes-iYM5eOb". Finished. Store the Port 3 trimmed in database ID 323. Saved to the file "D:\04-Working_folder\04-Star-CD\180304\xes-i3tkSbc\child_ice.dbs": trimmed cell data with id 323 Port 3 trimmed Cells Cell Tbls CP Match CP Tables Splines Splin Tbl Vertices 431806 1 0 0 0 0 1526730 ID 1463833 1 0 0 0 0 1694040 Trimmed: 10 Max Ent: 0 Finding the valve stem vertices. Sorting 494663 faces. Sorting 501466 faces. No path was found from the stem to the seat. Failed to find the collapsing layers for Port 3. "Trim,Recover" may allow you to fix the problem and continue. Failed to cut the Template. |
April 12, 2018, 01:50 |
Can
Rep Power: 13 |
i fixed this issue. thank you.
Foam::error::printStack(Foam::Ostream&) with pimpleFoam of OF1612 on Cluster | shang | OpenFOAM Running, Solving & CFD | 7 | January 24, 2018 08:30 |
define_wall_functions density and dynamic viscosity | Ionut G | Fluent UDF and Scheme Programming | 3 | March 15, 2017 10:10 |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
error 262144 and unexpected disconnect when run on 2 nodes | Emily1412 | SU2 Installation | 1 | April 10, 2014 17:08 |
About trim polyhedron of Es-ice | skylent | STAR-CD | 1 | November 7, 2011 02:24 |
