February 25, 2018, 23:15 |
analysis of 3D sector of piston
How can we analyse sector of a 3D piston in star cd , without creating 2d template.. I mean how can we analyse a piston with tangential holes into the compression chamber..I have provided an image for the same....when i created the spline , i didn't get a proper spline..both images are provided.. kindly help |
August 3, 2018, 16:47 |
Rep Power: 8 |
If you are still looking for an answer. For the es-ice sector tool, it has to have rotational symmetry.
August 9, 2018, 04:07 |
Can
Rep Power: 13 |
hi,
I don't know what you can try to fix your issue. but I am curious about that hole could you explain me shortly what the purpose of that hole is if it is not confidential? maybe a link for an article etc. thank you. |
August 9, 2018, 04:53 |
Rep Power: 8 |
Hi Cnaksoy, that was also on my mind. I would think the hole would increase soot and probably also undermine the swirl in the first place.
Piston Cylinder with constant pressure applied | shreyansh_rai | FLUENT | 0 | October 6, 2017 09:45 |
analysis of piston | pranavpatel652 | Main CFD Forum | 0 | March 4, 2016 19:31 |
Validation Process for CFX analysis of piston ring and cylinder liner with bio oil as | divyatiwari000 | CFX | 4 | July 11, 2015 06:46 |
Piston Cooling Nozzle Simulation | rajeev50588 | STAR-CCM+ | 1 | February 26, 2013 03:41 |
Piston Simulation | helloworld922 | Autodesk Simulation CFD | 1 | September 9, 2012 22:54 |
