Home > Forums > Software User Forums > Siemens > STAR-CD
Creating the 3D Template Problem
Old   March 7, 2017, 06:21
Default Creating the 3D Template Problem
Vaticannose is on a distinguished road
i got a problem when doing "Chapter 4 MESHING WITH THE TRIMMING METHOD
" "Creating the 3D Template
the last step i got a problem , i can not create the template.
Reading the valve lift file "vlift01.dat".
Reading the valve lift file "vlift02.dat".
Finished reading from the file "E:\starcd_practice\xes-i6iTcNc".
Creating template.
Finding connectivity for 1743 vertices.
Finding local structure.
Finished setting up elliptic smoother for 1595 vertices.
41971 vertices were moved for 69 iterations.
38399 vertices were moved for 36 iterations.
Sorting 1676 faces.
Sorting 462576 faces.
Save completed to the file "save_ice_tut".
Finished.
Failed to create the template.
Vaticannose is offline   Reply With Quote
problem with creating artery thickness for FSI methode using fluent and mechanical raminostadi FLUENT 1 June 6, 2020 06:17
[DesignModeler] Problem with creating thickness raminostadi ANSYS Meshing & Geometry 1 February 12, 2017 11:21
[ICEM] Problem creating prisms in baffle surface thernandez ANSYS Meshing & Geometry 0 July 26, 2016 07:55
[ANSYS Meshing] Problem creating two surfaces from two identical curves KingKraut ANSYS Meshing & Geometry 1 November 27, 2015 03:00
[ICEM] Problem in creating different zones in ICEM-CFD samurai_01 ANSYS Meshing & Geometry 2 November 28, 2012 13:41
