Problem with creating the 2D base template in es-ice 4.18 |
February 9, 2016, 08:34 |
Kevin
Hi All,
I am encountering with a problem in creating the 2D bas template for Valve 1. I manually created my valve profile as stated in User Guide with point p1, p2, p3, p4, p10, p20. My valve dont have chamfer so i select p1 and P2 with same radius. Now, during creating template, in the section 1 tool panel, i load vavle01.dat file and set all other parameters. When i pressed Create button, "could not create Section with the given parameters. Please check that the valve is inside the cylinder". However my valve is inside the cylinder and there is agap of 1.35mm between valve surface and cylinder surface. Please help me to solve this problem. Thanks Kevin G |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ANSYS Meshing] Problem creating two surfaces from two identical curves | KingKraut | ANSYS Meshing & Geometry | 1 | November 27, 2015 02:00 |
Having problem in creating a volume mech in GAMBIT | Jake | FLUENT | 1 | April 25, 2008 05:01 |
Problem in creating .geo file | SHABAH | CFX | 13 | April 25, 2001 02:22 |
