vad
Rep Power: 14 ![]() |
Please! Help. I work with the es-ice, and I rely diesel. Once I click Cut in Trim panel, calculations, and at the end of the error message:
"Saved: surface data with id 5 merged classified cylinder surface Cells Cell Tbls CP Match CP Tables Splines Splin Tbl Vertices 107266 6 0 0 0 0 52123 ID 219215 8 0 0 0 0 105748 Could not close the surface because there are 75 vertices on one side and 68 on the other. Failed to cut the Template." what can be done? |
John Wang
Rep Power: 13 ![]() |
I think you can modify/delete some splines, then you may figure out the problem.
ice melting simulation | pratikmehta | ANSYS | 3 | April 17, 2013 09:52 |
Es-ice trimming method | vadyashayah | STAR-CD | 6 | July 12, 2012 03:23 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
difference in the trimming and mapping method | guru | STAR-CD | 1 | April 25, 2011 10:48 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
