Pause a simulation and check intermediate results |
October 16, 2012, 09:52 |
Andrea Giorgi
Hi everyone,
I'm currently running a transient simulation on multiple CPUs. Since the calculation time turned out to be too long I'd like to stop the simulation and analyse the results produced so far. In the case folder at the moment I can't see the casename.ccmt file. If I use the command " star -kill " will the .ccmt file be generated? In case not, could you please suggest me how to proceed? Thank you in advance |
October 16, 2012, 11:27 |
Pauli
Rep Power: 17 |
If you do not have a .ccmt file it is because you either did not ask for transient output or your run has not progressed far enough to start saving transient results.
You can force star to save a ccmp like data set using "star -chkpnt". |
October 19, 2012, 06:59 |
zheng jianjun
Rep Power: 16 |
That's the good answer.
How to pause a transient simulation and resume without time step advancement? | aleisia | Main CFD Forum | 33 | June 12, 2017 12:41 |
error to check simulation result: could not find valid OpenFOAM mesh | xiaoyoyo | OpenFOAM | 5 | May 18, 2017 12:38 |
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 02:40 |
Grid check failed .... run simulation useless? | Zigainer | FLUENT | 2 | May 17, 2012 05:31 |
How to check the flowrate in a simulation including transient term | tsh850227 | CFX | 2 | February 13, 2012 07:54 |
