Problem with Data Mappers on our cluster
Old   April 6, 2012, 18:35
Default Problem with Data Mappers on our cluster
Jimmy
Jimmy123 is on a distinguished road
I'm using StarCCM+ 7.02 and I'm trying to use the data mappers to exchange heat transfer coefficients and temperatures between a fluid and a solid. It works perfectley fine when I run it on one computer (12 cores in parallel), but when I involve more than one host the solution seems to get stuck when it is suppose to mapp the heat transfer coefficient and the refference temperature to the solid for the first time. It dous not crash or report any error messages, it just keep on working without any success. Right before I try to mapp the values, I save a snapshot in the solution history, and that works without any problems. The computers on the cluster use Linux (CentOS).
If someone have a solution for this, or guidance about settings or whatever I should check, it would be appreciated
Jimmy123 is offline   Reply With Quote
Old   April 24, 2012, 18:04
Jimmy
The problem is solved, it had nothing to do with StarCCM+. I had placed my sim-file on one of the computers in the cluster, just as I was used to do with CFX def-files before. This location was obviously not reachable from the other computers, so it became problems when the history file were saved, even though the output prompted that is was done. Now I have moved my sim-file to a location on the network which is available from all the computer on the cluster and everything works fine
cluster, data mappers
how to compare unsteady state problem results from FLUENT with Experimental data? cuddaloreselvam FLUENT 0 July 10, 2011 09:25
Tecplot360 problem for reading OpenFOAM data maysmech OpenFOAM Post-Processing 5 April 13, 2011 16:37
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 12:39
Problem in Track Data selen Siemens 2 August 7, 2003 14:06
retrieving data of a previous problem for the next manabendra das Phoenics 2 January 28, 2001 11:17
