How to model Eulerian multiphase and Species Conservation at the same time?
Old   March 13, 2012, 12:49
Default How to model Eulerian multiphase and Species Conservation at the same time?
Can Huang
onlyacan is on a distinguished road
Hallo ,everyone
I am going to model a solidification process.
I use the Multiphase segregated flow model to model the solidified phase and melt phase. These phases are all of multi-components.
Problem is : When the Multiphase segregated flow model is selected, the Multi-Component Liquid models can not be selected.
That's to say, in starccm+, How can I solve the species conservation equations while the mass conversation equations with volume fractions are solved?
Thank you very much if any one have those experience
onlyacan is offline   Reply With Quote
Old   March 13, 2012, 13:38
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Can you explain more?
After you selected the Multiphase model you can determine the material you need.
Check the tutorial for the Eulerian.
siara817 is offline   Reply With Quote
Old   March 14, 2012, 07:22
Can Huang
Thank you very much for your reply
problem description: two phase flow with two components
I want to model a solidification problem, the material is a melt. Its two components are iron and carbon. Carbon can diffuse and convect in the melt.
I use Multiphase segregated flow to model the phase change(from liquid to solid), in each phase, at the same time I want to know the carbon distribution in the melt, so I have to solve the species conservation equations for each Euler phase(melt and solid).
In the Material selection, Multi-Component Gas and Multi-Component Liquid models can solve the species equation, but in a single phase. Beside them, Multiphase Mixture can be choosen. So I choose Multiphase Mixture. Then under the Multiphase Flow Model there are two models, one is Multiphase Segregated flow, another is Volume of fluid (VOF). This is the problem! I want to solve the species equations with Multiphase segregated flow model. But if I use Multi-Component Liquid model I can't not choose Multiphase Mixture at the same time.
Old   March 14, 2012, 09:28
siara817's Avatar
In the icon, Multiphase Interaction you need to define the two interchages ( carbon-melt and carbon-solide).
eulerian multiphase model, multi component, solidification, starccm+
Multiphase model and species transport Reginaldo Cotto FLUENT 1 June 6, 2024 05:02
Eulerian multiphase model for species trnasport: UDF for reaction rate harsh Main CFD Forum 3 June 12, 2017 03:24
Species Transport with Multiphase flow in FBR venkat FLUENT 1 July 24, 2008 00:53
Eulerian Multifase model with species transport Valeria FLUENT 0 July 19, 2008 17:48
Species Transport with multiphase flow Gopal Kasat FLUENT 3 July 12, 2005 19:59
