Stable LowRE model
Old   March 8, 2012, 15:00
Default Stable LowRE model
M10
Mio S
M10 is on a distinguished road
I'm having difficulty obtaining a cleanly converged solution when for lowRe simulation. I've tried Standard k-e lowRe, AKN-k-e, and both of them produce answers that are quite oscillatory for all iteration counts. For the range of Re = 1e4-1e5, what are the reasonable turbulence models people use?
Thanks.
M10 is offline   Reply With Quote
Old   March 10, 2012, 03:46
abdul099 is on a distinguished road
Usually oscillations are no issue but physical behaviour. There are just a few really steady flows, you can nearly count them with the fingers of your hands. Most physical problems are unsteady, especially for higher Reynolds numbers.
So I assume, your chosen turbulence model is fine and the oscillations are just because the sovler tries to solve the physics.
abdul099 is offline   Reply With Quote
low reynolds, turbulence model
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 05:43
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 10:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
