Mass Transport Simulation
Old   March 6, 2012, 07:27
Default Mass Transport Simulation
bioflow is on a distinguished road
Just wondering has anyone used Star CCM+ for mass transport simulations?
I'm hoping to simulate the build-up in concentration of dye particles within an aneurysm shape, but have started with just a straight pipe to try work out the best method for the simulation first. I've been using multi-phase flow with two Eulerian phases - liquid (water) and particle (dye)...however, the post-processing is proving difficult. Has anyone looked at concentrations, or something similar to this? Any general advice?
(I'm a newbie to CFD so apologies if the description is vague)
bioflow is offline   Reply With Quote
Old   March 6, 2012, 09:12
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Have you tried the field function Mass flow rate of particle?
Other think is that I am wondering, why do not you use the Lagrangian multiphase ?
siara817 is offline   Reply With Quote
Old   March 7, 2012, 06:42
siara817's Avatar
If you want to use the Eulerian multiphase, you can generate a Scalar Scene and then for the field function, go to mass flow rate. you will have two choices, water or particle. select that one you like.
good luck
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 12:02
buoyancy flow and mass transport rembe COMSOL 0 October 14, 2009 07:01
Incompressible with mass transfer simulation kuhbuh CFX 4 June 8, 2009 21:47
Mass Transport in Arteries paul FLUENT 0 August 20, 2002 06:44
