Convergence Issues 2D Airfoil
Old   February 27, 2012, 11:31
Default Convergence Issues 2D Airfoil
Aaron Kuenn
AeroEngiNerd is on a distinguished road
I'm trying to run a low speed (M~0.3) 2D airfoil case in STAR-CCM+. I'm running into issues with convergence, specifically in y-momentum (it only drops about 1 order of magnitude, while the others drop 2-6). I was posting on here to hope someone could spot a rookie mistake that I'm making.
Domain - Rectangular domain, ahead of the airfoil 15 chords, behind 40, above and below 20.
I'm using an Inlet with specified speed, pressure outlet, and above and below are free-stream. The flow specifications were calculated based on a chosen temperature and velocity, and using atmospheric pressure.
The mesh is about 1 million cells, and the smallest cell size is approximately 0.005 in. I'm using a trimmed mesh and a prism mesh with 7 layers.
The solution is being run with a Coupled solver, with k-omega turbulence, and ideal gas flow.
Finally, while the solution is not "converged", it does seem to have the correct Cp shape. I haven't done detailed comparison of the Cp distribution, due to the lack of convergence. However, the Cp distribution does seem to be scalloped, or small peaks in the data on both the upper and lower surface about every 3-5% of the chord. Is this related to the lack of convergence or is this another issue entirely?
Any help you can provide would be most appreciated. Thank you in advance.
AeroEngiNerd is offline   Reply With Quote
Old   February 28, 2012, 10:34
willimanili is on a distinguished road
If your simulation isnt canceled due to divergence, dont look only at the normalized residuals to judge if your simulation is converged or not.
Create some reports of significant values like drag or lift force, velocities, pressure and so on and monitor them to judge the convergence.
Maybe the "Judging Convergence" chapter in the user guide help your understanding.
willimanili is offline   Reply With Quote
2d simulation, convergence, pressure distribution, star-ccm+, y-momentum
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Force can not converge colopolo CFX 13 October 4, 2011 23:03
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 08:22
convergence issues on steady state solver icemaniac178 CFX 1 March 30, 2011 20:11
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
