HTC: How to choose reference temperature value
Old   February 27, 2012, 08:26
Default HTC: How to choose reference temperature value
halcyon is on a distinguished road
I am doing a simulation (laminar,steady) to predict the HTC between a solid body (23°C) and air (20°C).
I thought that the temperature reference value you can choose in the HTC field function should be somehow related to the air temperature in my case.
But if I choose the T_ref 20°C I get an HTC interval of [-1.5,18]. If I choose T_ref 18°C the HTC look much better within an interval of [-0.5,5].
Is there any rule how to choose this value and is it OK to use that value that makes the simulation more realistic?
For me such a "playing around" method doesn't seem to be very professional...
halcyon is offline   Reply With Quote
Old   April 12, 2012, 07:07
Default reference value
misagh
misagh is on a distinguished road
i have the same problem.
i dont know which tem. to choose for ref. value.
a tube entering water @300 exiting @302
it is so sensitive to tempreture value.
any help is appreciated.
misagh is offline   Reply With Quote
Old   April 12, 2012, 09:19
Robert
RobertB is on a distinguished road
Typically HTCs are referred to the bulk entrance gas temperature, as it is easy to measure experimentally.
If you have very low T rises then it is not surprising that your HTC will move around significantly as the dT is very small.
You will need to use variable fluid properties and an appropriate grid. You also need to make sure that your model is set up exactly the same as the experiment it is trying to reproduce.
RobertB is offline   Reply With Quote
Old   April 12, 2012, 12:46
misagh
yes.you are right.when i choose enterace tempreture the diagrams trend is like that of the experimental diagram,but with significant error./exp. digram is available/
thats because of mesh unaccuracy.
any way,thank you Robert.
htc, reference temperature
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
[Commercial meshers] Conversion form .ccm to openFoam ViktoriaE OpenFOAM Meshing & Mesh Conversion 1 November 29, 2011 17:40
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 04:12
Reference Temperature Rob Siemens 2 April 12, 2003 04:27
