VOF and multiphase segregated flow
Old   February 9, 2012, 13:51
Default VOF and multiphase segregated flow
natalie26 is on a distinguished road
i hope someone can help me
i took the VOF model to simulate a gas flow above a constant water level.
Additionally i want to simulate a water injection at the inlet.
As far as i understood the tutorial i need to use the segregated flow for a continuous-dispersed phase? Or is it possible to define a massflow of 50% water and 50% air while using the VOF model?
thanks for help!
natalie
natalie26 is offline   Reply With Quote
Old   February 9, 2012, 15:12
Ladnam is on a distinguished road
Usually it is better to use the multiphase segregated model when air is dispersed in water, like for a inlet with fractional flow. Use VOF when you have an interface between water and air that is important to capture, e.g. boat on free surface. Be patient with the multiphase segregated model, it is harder to get it to converge than the VOF model.
Ladnam is offline   Reply With Quote
Old   February 9, 2012, 16:38
yes i do have to capture the interface between the water on the bottom of a valve and the gasflow streaming over it. so far it works (with the vof model)
but now i donīt know how to generate the water droplets in the airflow at the inlet...
in the hibiki bubble tutorial they defined the inlet with air and bubbles with different velocities and air as the continous phase. but there the multiphase segregated flow is choosen and no additional water surface is present can i define such an inlet with the vof model?
thanks!
Old   February 18, 2012, 07:34
abdul099 is on a distinguished road
Have a look on the user guide, it explains the limits of VOF.
In order to capture bubbles or droplets with VOF, you need a mesh resolution significantly smaller than the bubbles or droplets. That's too much effort for most applications, better to do that with an Eulerian / Eulerian approach (multiphase segregated flow in ccm+).
Water at the inlet can be specified by setting an appropriate volume fraction at an appropriate position, therefore you might use a field function. But don't expect a nice result as long as your mesh resolution doesn't meet the requirements.
abdul099 is offline   Reply With Quote
Old   February 21, 2012, 16:01
so...the results with the vof model are quite good! Indeed the mesh is very very fine!
I was thinking about using the lagrangian-model to specify an injector at the inlet. Isnīt this easier than using a field function?
There i can specify water droplets with a specific diameter and velocity.
I donīt know if this will work...? Can i combine these models?
Until now i always get a floating point exception, but it could be the initial conditions...
thanks for your answers
Air-water interface in a channel flow using VOF method Chocosoboro FLUENT 0 April 6, 2011 11:04
Multiphase flow and convergence issues Erik FLUENT 1 July 13, 2009 18:08
multiphase flow VOF model set up rahaman FLUENT 0 June 9, 2009 04:49
multiphase flow heat transfer yeeking86 CFX 1 April 16, 2009 09:29
VOF transfer - multiphase flow karthik Main CFD Forum 4 February 2, 2006 02:25
