January 10, 2012, 02:31 |
unable to float the boat!!
aerosapien
Rep Power: 16 |
I am working on tunnel hull speed boat. The wave generated is making the body submerged even with less amplitude of wave. Please help me resolve the problem!!!!
January 10, 2012, 04:30 |
Ping
Rep Power: 20 |
ensure your boat flows in still water first in still water - weight could be incorrect.
January 10, 2012, 05:24 |
aerosapien
Rep Power: 16 |
it doesn't folat it appears submerged. Should I change the position of ship ? serious help required!!!
January 10, 2012, 05:51 |
Ping
Rep Power: 20 |
as I said you need to run with zero in/out flow the case for a few seconds (eg using a timestep of about 0.05s) and monitor vertical motion (sink). if there is no movement then the gravity forces are balanced by the bouyancy forces. if the hull is in a submerged condition after this run, then your hull mass is too high for this hull shape - simple hydrostatics. do the boat tutorial in the Help if this does not understood. ensure you have freed the required DOFs!
January 11, 2012, 00:01 |
aerosapien
Rep Power: 16 |
I found the solution myself. Actually its got nothing to do with buoyancy. Just go to VOF wave >> head wave >> adjust the point on water level, its simple as that. Thanks for the sharing your opinion. Some more questions to come
http://aerosapien.blogspot.com/ |
January 11, 2012, 01:54 |
Ping
Rep Power: 20 |
well if you had followed my instructions, the boat would rise to the surface of where your flat wave had been incorrectly set, so it is in fact about bouyancy!
January 11, 2012, 23:54 |
aerosapien
Rep Power: 16 |
OpenFOAM and gpgpu | dewald | OpenFOAM | 37 | August 29, 2014 10:32 |
openfoam 1.6 on debian etch | romant | OpenFOAM Installation | 9 | May 6, 2010 03:26 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 16:45 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
to correct me an udf program | farida hamadi | FLUENT | 0 | December 18, 2004 06:54 |
