Pump characteristic / performance curve
Old   January 3, 2012, 11:45
Default Pump characteristic / performance curve
husker is on a distinguished road
Hi all,
I am trying to build the performance curve of a centrifugal pump.
I do know the design point (mass flow rate and rpm).
However I need the performance curve (mass flow rate vs. head).
I tried the followings:
1) I set 40, 60, 80, 140, 160, 180 percent of design mass flow rate at the inlet and monitored the output pressure. Outlet BC was pressure outlet.
2) I tried fixing several head values by setting different pressure values at the inlet and outlet at a constant rpm. Inlet and outlet BCs are pressure outlet.
Finally I monitored pressures and velocities and none of my all simulations converged.
Any ideas about what is wrong? Or any recommendations about how to build the performance curve?
Regards
husker is offline   Reply With Quote
Old   January 15, 2012, 08:54
Ladnam is on a distinguished road
If you give more information about your model it is easier for people to answer. Maybe your underrelaxation factors are too high.
Ladnam is offline   Reply With Quote
Old   February 18, 2012, 09:10
abdul099 is on a distinguished road
Originally Posted by husker View Post
... and none of my all simulations converged.
How do you judge convergence?
abdul099 is offline   Reply With Quote
Old   February 20, 2012, 04:42
Hi all,
Regards
My solutions converged with Mass Flow Inlet & Pressure Outlet BCs. But I can't simulate with two pressure boundaries. I set static pressure at the outlet to zero and fix total pressure at the inlet. Do you have any ideas?
Old   February 20, 2012, 04:46
By the way, I set total pressure by using Stagnation Inlet BC.
Pump or fan characteristic curve A Arvelo CFX 6 March 27, 2016 10:11
CENTRIFUGAL PUMP, characteristic curve Ivanrips CFX 4 September 14, 2010 11:29
plotting a performance curve of centrifugal Fan altano CFX 2 October 18, 2008 08:12
Pump characteristic curves JSM FLUENT 2 May 12, 2008 00:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
