December 13, 2011, 11:06 |
non-manifold error
vincent
Rep Power: 15 |
I want to obtain my fluid domain by either extracting the internal volume or using the boolean operation substract or intercepts on my geometry which I imported under; import CAD Model. However all my attempts resulted in error stating on one hand,
"feature execution failed, non manifold body extracted" and on the other hand, "feature execution failed, substractbodies: substract will produce non manifold body" can you help me with a step by step method of dealing with these two scenarios so as to obtain the fluid domain. Also what are the steps for dealing with free edges and non-manifold edges and vertices |
January 2, 2012, 19:54 |
Rep Power: 22 |
I can't provide a step-by-step method since I don't know anything about your geometry. All I can try is giving some hints. When your imported part has some free edges or some other errors, try to get rid of them before importing the geometry (when possible). Otherwise import your geometry on the part level (not CAD modeller) and repair all errors by hand before performing boolean operations.
Again I can't give you any step-by-step methods how to get rid of free edges, non-manifold edges or non-manifold vertices since it depends on your geometry. Sometimes you can fill free edges, you might zip some, you might make an intersect and delete some faces etc... Try to understand what a free edge, a non-manifold edge etc. means and you will see what to do. |
boolean, extract, free edges, internal volume, non-manifold |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 02:40 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
