Heat Exchanger
Old   November 11, 2011, 05:09
Default Heat Exchanger
Hamza Motiwala
hamzamotiwala is on a distinguished road
Hello everyone,
I am working on a heat exchanger model which is a part of an exhaust gas recirculation system.
I define this part as a seperate porous region(so that I can restrict the flow in certain directions and also sort of create a baffle/airfilter effect) and what I am trying to do is to reduce the exit temperature of the air that enters this region.
I just define this region as a Heat exchanger.
I have tried this by giving in a fixed wall temperature and i have also tried this with the help of the "Energy transfer option". I also specify the exit temperature. I just cant get it right.
The temperature of the air at the inlet is about 350K and I want this to reduce to 320K. There is no second working fluid. The Problem is that the air always cools to a temperature below 0K within the porous region. I have tried giving in a wide range of values and its always some sort of negative temperature profile that I get. I know I am doing something wrong.
If anyone has any idea about whats happening here, I would really appreciate some advice.
If you want more specifications I can provide it or if I am not clear enough I can elaborate.
Thanks,
Hamza
hamzamotiwala is offline   Reply With Quote
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 02:29
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 14:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
