October 20, 2011, 22:39 |
mesh quality?
adam
Rep Power: 15 |
I'm new to using STAR-CCM and was wondering if there are some general guidelines to mesh quality? Take for instance my problem: I'm simulating the forced convection of an eletrical component (simplified as a 'block') in a duct using a baffle to help cool it. I am basically interested in knowing the surface temperatures on the block and the flow around it. There's a volume control around the block. Basically I just kept refining the mesh until my results did not seem to change. Also, is there a way to check y+ values once the mesh is created?
October 20, 2011, 23:31 |
Rep Power: 22 |
There is no way to check Y+ only after meshing without solving. Y+ is not just a geometrical value but also influenced by the flow. So you need to solve at least until the solution will not change that much anymore. Then you can create a scalar scene and display y+ on all walls you are interested in.
General guidelines for mesh quality is quite simple: As high as possible. The better the mesh quality, the better the solution. When the preview of the "remove invalid cells" function finds more than just some single cells, it's always suspicious. It's also pretty often possible to create a section scene, display the mesh on the section plane and look at it near corners, edges, small features etc. When it looks bad, it is bad in the most cases. But regarding your description, I assume, you are more interested in mesh sizes than mesh quality. Even a "perfect" mesh in terms of cell quality can be too coarse to obtain a good solution. So refining is quite important, but there is no general rule how far this should go. Some people say, as far as needed to get a mesh independent solution, but for most cases this is just impossible when one wants to get the solution still in this decade. Anyway I think you're on a good way, as you're refining until the results seem not to change anymore. |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 08:38 |
[snappyHexMesh] mesh quality control and fix | tachyon_me | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2009 13:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
