Transient analysis of particle flow with Fluid-Structure Interaction (FSI) |
Julian Krick
Rep Power: 17 ![]() |
Hello!
I would like to simulate the following scenario: - flow over an oscillator (beam) -> Fluid-Structure-Interaction (FSI) - particle tracking during oscillation of the beam - capture (immobilization) when particle touches the beam's surface I know, that particles can be introduced and tracked in post-processing. However, my scenario requires a simultaneous simulation of flow and particle flow. Furthermore, the particles should be captured and counted when they hit the beam's surface. Would it be possible to simulate this scenario with Star-ccm+? Thank you! Cheers, Julian
grid generation: ICEM CFD 13.0 solver: CFX 13.0 |
siamak rahimi ardkapan
Rep Power: 18 ![]() |
hi,
For particles you need to introduce the lagrangian model in your phisycs model. Then, specify the characteristics of the particle in the lagrangian model. I am not sure about counting the number of immobilized particles, but try to see boundary values for particles, get help from the toturial. Good luck |
Julian Krick
Hi!
Thanks for the response. I'll use CFX now. I found a way to implement particles as a discrete phase. Cheers, Julian
cfd, fsi, particle tracking, structural mechanics, transient |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Fluid structure interaction on baloons | vinz | OpenFOAM Running, Solving & CFD | 38 | September 14, 2016 12:38 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Fluid and Structure Interaction | MrAnderson | ANSYS Meshing & Geometry | 1 | October 8, 2010 16:04 |
Fluid structure interaction. | Haree | FLUENT | 2 | August 7, 2010 02:56 |
