How can i animate an unsteady simulation in Star ccm
Old   July 7, 2011, 08:28
Default How can i animate an unsteady simulation in Star ccm
Elena Cortin
eleazar is on a distinguished road
I run a simulation of 1000 iterations and i would like to see all the timesteps from the first to the end as an animation
So how can i do that? i can not find any tutorial
Also how can i delete the last 100 iteration and start from the 900 ??
eleazar is offline   Reply With Quote
Old   July 7, 2011, 09:30
Ste
Ste is on a distinguished road
You can export the scene at a set timestep interval, and then compile in movie maker or a similar program. To do this go to
scene > attributes > update
then click on the save to file button and specify the directory. If you click on the update frequency tab can set how often the file will export.
As for the second question, I would probably set to autosave every 100 timesteps in 2 files (so one file saves the 100, 300, 500 etc up to 900th timestep) and then restart from that point.
Hope that helped
Ste
Ste is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
simulation created in star CCM 5.06 yin STAR-CCM+ 1 May 4, 2011 03:29
Fluent Vs Star CCM firda Main CFD Forum 3 February 26, 2011 03:51
CFD-analysis of hydroplane: STAR CCM or Flow Simulation? peterg07 Main CFD Forum 0 February 7, 2010 15:32
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 05:37
