Mesh issues
Old   May 30, 2011, 00:02
Default Mesh issues
famerfamer is on a distinguished road
Hi Guys,
I just meshes a bundle (full of pipes) but the skewness angle are around 95. Those bad cells are located on the walls outside the bundle as illustrated in the picture. The geometry is also shown in the picture.
What should I do? I've refined the whole bundle by decreasing the base size of the mesh a lot (four times, every time decreasing by a ratio of 1.3). The problem is still there.
Thanks for your help!
Famerfamer
famerfamer is offline   Reply With Quote
Old   May 30, 2011, 07:34
alastormoody11 is on a distinguished road
Instead of changing the base size which will lead to a large increase in the cell count, you can try putting the pipes creating problems in different boundaries by splitting them interactively and then set smaller custom surface sizes, so that those areas are captured by means of local refinement.
alastormoody11 is offline   Reply With Quote
Old   May 31, 2011, 16:31
Thanks for your reply.
Is there any difference if I use volumetric control to only refine those walls where those bad cells are located? I mean to use a very thin block to cover those walls. But I'm not sure if only by refining walss the problem can be solved. How do you think?
Thanks,
Famerfamer
Old   May 31, 2011, 18:02
BTW, to creat boundaries, I need to split the whole boudary by patch which will kill my computer almost cuz there will be too much boundary generated then. Currently I had 67Million polyhedral cells for the mesh. So you can see it's not a small one. Thanks.
Old   May 31, 2011, 18:53
Can I use 'split boundary by patch' to define a boundary locally (like only the problematic areas? )instead of split the whole boundary of the geometry into pieces of patches?
Thanks for you help.
Famerfamer
Old   June 1, 2011, 11:38
You're right... I try to refine those walls and there has already been 11Million surface meshes generated which is toooo large for a volume mesh...
Help... Does anyone have a good idea?
Old   June 8, 2011, 22:41
Dave
daveatstyacht is on a distinguished road
You could try repairing the base surface either with the surface wrapper or manually (it's a pain, but sometimes and hour of geometry clean up can save you a week of meshing). A lot of times the a poor underlying geometry can make a mess of things (trailing edges on wings, stl files, etc). The manual repair feature is found by right clicking on the import tab of the "representations" directory. Hope this helps
daveatstyacht is offline   Reply With Quote
[Gmsh] Issues with mesh tolerances after using gmshToFoam madad2005 OpenFOAM Meshing & Mesh Conversion 1 August 20, 2014 06:10
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
