Uninitialized Wall Shear Force on boundary
Old   May 11, 2011, 10:18
Default Uninitialized Wall Shear Force on boundary
ZS
ziyasaydam is on a distinguished road
Dear all,
I got the following error while starting an analysis with the segregated multiphase solver:
"Uninitialized Wall Shear Force on boundary: HUll. Please initialize the solution or solve an iteration/timestep"
Does anyone have an idea how to overcome this?
Thanks in advance,
Ziya
ziyasaydam is offline   Reply With Quote
Old   May 11, 2011, 13:01
Ryne Whitehill
rwryne is on a distinguished road
Originally Posted by ziyasaydam View Post
Dear all,
Thanks in advance,
Ziya
Long shot, but try doing Solution->Clear Solution and starting it again?
rwryne is offline   Reply With Quote
Old   May 11, 2011, 13:03
ZS
already tried that.
Old   March 28, 2012, 20:31
Payam Mehrpooya
payammehr2 is on a distinguished road
Send a message via Yahoo to payammehr2
already tried that.
I am getting the same thing, but for pressure.
Uninitialized pressure on boundary. please initialize ...
Did you figure out how we should get rid of this problem?
Thanks
payammehr2 is offline   Reply With Quote
Old   March 29, 2012, 03:40
ZS
not really. also, it looks like it's not a common problem. have you tried contacting the support?
Old   November 12, 2013, 15:53
Tommy
Koki is on a distinguished road
Hello Guys,
I faced similar problem ,I would appreciate your suggestion.
Regards,
Tommy
Koki is offline   Reply With Quote
Old   December 2, 2013, 11:42
EnronZhang is on a distinguished road
Hi ziyasaydam,
I've just got the same problem as you have. Have you figured out how to solve this problem now? Looking forward to your reply. Many thanks!!
Enron
EnronZhang is offline   Reply With Quote
Old   January 14, 2014, 09:20
Soenke
pavelow is on a distinguished road
Hello all,
I am reading this forum for quite a while now and I found a lot of help for different problems I had. Maybe i can give now a hint concering to this error message.
I had a simular problem. I am simulating a rotor. I am using a Multi Reference Frame to simulate the rotation. I want to have a look on the moment report. Therefor I selected my MRF region and my stationary region as part for the report. I got the message: "Uninitialized Pressure on boundary: MRF/Stationary [...]. Please initialize the solution or solve an iteration/timestep."
After contacting the support, I could fix my problem. I had to remove my MRF/Stationary Interface from my moment report. Since this interface is placed within the fluid region, it isn't possible to calculate any moment of force there. After that, everthing works fine.
In a future release, there will be an error message for this problem, which is more precise. Maybe this can help you with your problem.
Regards,
Soenke
pavelow is offline   Reply With Quote
Old   March 12, 2015, 10:55
Default Solution
mhq
Manu
mhq is on a distinguished road
Hello, I recently had this problem, and your answer helped me fixing it.
In my case, I was performing a multiphase simulation. I had run a single-phase simulation in the same file earlier, and had some reports associated to variables of this single phase.
By deleting these reports, I could make the simulation run
Hope it helps if someone has this problem in the future.
The exact message was:
"Uninitialized solution. Please initialize the solution or perform an iteration"
Thank you very much
mhq is offline   Reply With Quote
Defined Wall Shear Stress Boundary Condition mart.hein OpenFOAM Programming & Development 1 April 14, 2011 13:44
How to set up shear stress in wall boundary? DrHilton Main CFD Forum 0 April 8, 2011 07:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Wall Shear Force Bo B. B. Jensen Main CFD Forum 3 January 28, 2000 18:48
