Field function cannot be evaluated on region
Old   April 26, 2011, 17:48
Default Field function cannot be evaluated on region
Paulo Arthur Beck
pauloabeck is on a distinguished road
Hello All,
I'm trying to implement a user field function which is supposed to return the viscosity of a non-Newtonian fluid given the strain rate magnitude and other threshold parameters. I'm aware of the solver parameter "Temporary Storage Retained" which is set to true.
When trying to run the simulation, I'm receiving the message "Field function "SMD Viscosity" cannot be evaluated on region cell-2", where "SMD Viscosity" and "cell-2" are particular to my simulation.
Has someone faced this issue?
Thank you all,
pauloabeck is offline   Reply With Quote
Old   April 28, 2011, 18:33
abdul099 is on a distinguished road
There's an error in the definition of the field function "SMD Viscosity".
Check whether all field functions referenced in "SMD Viscosity" are existing, no mistypings occured and you have put in the right names.
abdul099 is offline   Reply With Quote
Old   April 28, 2011, 19:40
Paulo Arthur Beck
Thank you Abdul099. I've found the problem to be a variable name ill defined. The correct function definition, as a sample to others in need of help, looks like the following one:
($Iteration<1) ? $eta0 : (1-exp((-$eta0*$StrainRate)/$tau0))*(($tau0/$StrainRate)+$KConsistency*pow($StrainRate,$nBehav ior-1))+$etaInf*(1-exp(-$etaInf/($KConsistency*pow($StrainRate,$nBehavior-1))))
The $StrainRate variable is available only if the "Temporary Storage Retained" solver property is set to true. $StrainRate is the modulus of the mean strain rate tensor (Eq. 450 from the User's Manual).
field function, star ccm+
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
UDF vs Custom field function andrew FLUENT 5 June 24, 2011 11:53
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
field function in STAR-CCM+ stu Siemens 1 May 9, 2008 12:11
Custom Field function...>>>Please HELP..! sushii FLUENT 2 October 11, 2007 02:04
