bionic bender vs. 90° reference bender
Old   March 10, 2011, 13:29
Default bionic bender vs. 90° reference bender
hhuh huhu
weigsi is on a distinguished road
Hi community,
i have simulated a real test about the pressure drop over an evulotionary developed bender (maeander bender) vs a reference 90° bender.
In the real test the maeander bender generated a pressure drop around 15-25% less the reference one.
I build the exact geometrie of both bender in starccm+, and reviewed both in some simulations with following specs:
1. K-Omega - SST, Low y+
2. K-Omega - SST, All y+
3. RSS - Linear Pressure Strain, Two Layer
I used in physic-continuum, gas - air, steady, segregated flow, 3-D and turbulent.
The Mesh is genereted to have an overall y+<1 with the low y+, and between 30<y+<60 with the all y+/two layer wall treatment.
My problem ist that in starccm the maeander bender creates a higher pressure drop then the reference bender, but this in confict to the real results.
I hope u can give me any explanation for this case.
regards weigsi
weigsi is offline   Reply With Quote
bender, flow, how to, mesh, problem
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
