Seeting up Permeable Surfaces for use with FW-H Acoustics in CCM+
Old   February 24, 2011, 06:37
Default Seeting up Permeable Surfaces for use with FW-H Acoustics in CCM+
Matt Hollins
Reynolds is on a distinguished road
Hi all,
I have found the CCM+ tutorial on using the FW-H analogy for aeroacoustics incomplete. It gives directions for setting up the impermeable surface (wall boundaries) but does not do so for the permeable surface - a very important feature when using FW-H!
I was hoping someone else might be able to point me in the right direction. When I try and set up a permeable surface I cannot select any parts to use as the surface - how do I go about this please?
I would also be grateful for any warnings of pitfalls I may encounter whilst conducting my analysis.
Thanks,
Matt
Reynolds is offline   Reply With Quote
Old   February 25, 2011, 13:22
Vinicius Girardi
Vinicius is on a distinguished road
You must create those surfaces inside the model as internal interaces and use them as permeable surfaces in the FW-H model.
Vinicius is offline   Reply With Quote
Old   February 28, 2011, 16:27
Matt Hollins
Thankyou for your reply Vinicius.
I have managed to do this now, however I am unsure what to set the boundary type to?
For example I have created a landing gear geometry. I have then created a sphere around this and set it up as an internal interface. The boundary still exists as a viscous wall though.
I want the boundary to not affect the fluid dynamics at all. Even setting it as a freestream condition would alter my results as flow features would not be able to propagate properly.
How do I counter this?
Thanks again for your help.
Matt
Old   February 28, 2011, 16:30
Matt Hollins
Ahh, I think I may have been confused.
As the boundary does not have a part selected for it, then I do not think it exists and so is not a problem. I have selected the sphere for the internal interface though.
Is this correct?
Matt
Old   February 28, 2011, 16:40
Vinicius Girardi
Thatīs correct. Once you create the interface between the boundaries they donīt have anymore their properties, but the interface ones...
So, for your permeable surface, select the internal interface youīve created.
Old   December 12, 2016, 09:53
Polard
kamal tewari is on a distinguished road
Hi Reynolds
How were you able to calculate the overall sound pressure levels ? can you explain as I am modelling the jet noise and is facing similar problems.
kamal tewari is offline   Reply With Quote
Old   December 13, 2019, 03:36
Federica Fregosi
fedora is on a distinguished road
Can you please tell me where do you find the tutorial CCM+ on using the FW-H analogy for aeroacoustics? Thank you.
fedora is offline   Reply With Quote
Old   May 24, 2024, 00:13
OREOMax is on a distinguished road
Hi Vincius, could you please explain this operation more specific?This is a question from 2024 and STARCCM still got no tutor about creating permeable interface.
My email adress is
825543420@qq.com
or
gwf-1000rd@outlook.com
OREOMax is offline   Reply With Quote
aeroacoustics, ccm+, fw-h, permeable, star-ccm+
