Stream-wise velocity profiles
Old   February 3, 2011, 03:04
Exclamation Stream-wise velocity profiles
Girish Gaikwad
girishg is on a distinguished road
Hi guys,
Can anybody please tell me how to create stream-wise velocity profiles in a specific plane using StarCCM+?
I am running 3D simulation over a bluff body. I wanted to see stream-wise velocity profiles on center-plane in the wake. Can you please help me out with this. I am stuck with this problem from the long time. I really appreciate your help. It will be very helpful even if give me a little bit of hint. I am a novice in CFD field, I also tried using XY plot to plot the profiles, but was not able to do so.
Thank you.
-Girish
girishg is offline   Reply With Quote
Old   February 4, 2011, 06:24
mmaukii is on a distinguished road
Do not know it it is that what you want, but u can try i with a derived part. Make a plane and integrate it afterwards in a scene.
mmaukii is offline   Reply With Quote
Old   February 4, 2011, 12:59
f-w
f-w's Avatar
f-w is on a distinguished road
Sounds like a "vector" displayer in a scene is what you want. Look it up in the help file.
f-w is offline   Reply With Quote
Old   February 4, 2011, 14:52
Ryne Whitehill
rwryne is on a distinguished road
This.
Make a section cut in derived parts, then add it to a scalar displayer. In the scene/plot tab, right click Displayers->New -> vector displayer. add cut in
rwryne is offline   Reply With Quote
Old   February 5, 2011, 02:02
Default thanks
Girish Gaikwad
Hi guys,
Thanks for the help. I am attaching the streamwise velocity profiles, I saw in some paper. I want to replicate them. Can you please refer to the attached images?
Thanks again. I really appreciate your help.
Old   March 30, 2013, 12:40
Ontario
ranpreetbhatia is on a distinguished road
Originally Posted by girishg View Post
Hi guys,
I wish to do something similar on an airfoil. Were you finally able to achieve these velocity profiles.
Anybody else with experience in extracting boundary layer and velocity profile is welcome to help. Many Thanks in advance.
I have access to Tecplot and Ansys CFX
ranpreetbhatia is offline   Reply With Quote
profiles, starccm+, velocity
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Streamfunction? cain Main CFD Forum 5 July 19, 2012 11:05
Time-Varying Temperature Profiles shepardsp ANSYS 3 October 17, 2010 15:36
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 13:00
HELP - stream function from the velocity field Fred Main CFD Forum 10 January 26, 1999 13:58
