Automatically starting a run
Old   January 26, 2011, 05:07
Default Automatically starting a run
Dora is on a distinguished road
Hi everybody,
let’s say I have a set-up which takes 1hour to run. So in theory, when I leave work at 5pm and come back next morning at 8am,
the system could have ran a dozen of simulations. So is there a possibility to start the next simulation once the previous one is done (something like a “batch-run”)???
Regards,
Dora
Dora is offline   Reply With Quote
Old   January 26, 2011, 07:23
Oliver Lauer
olauer is on a distinguished road
You can run Star-CCM+ in batch mode ( -batch file.java).
Imagine a file called run.java containing something like:
// STAR-CCM+ macro: run.java
package macro;
import java.util.*;
import java.io.*;
import javax.swing.*;
import star.common.*;
import star.base.neo.*;
import star.vis.*;
import star.base.report.*;
import star.flow.*;
public class run extends StarMacro {
public void execute() {
execute0();
private void execute0() {
try {
Simulation simulation_0 =
getActiveSimulation();
simulation_0.getSimulationIterator().run();
simulation_0.saveState(simulation_0.getSessionPath ());
} catch (Exception e) {
JOptionPane.showMessageDialog(
null, e.toString()
then you could run
starccm+ -batch run.java file.sim.
You could add some of these command lines in a batch script.
Have fun
Oliver
olauer is offline   Reply With Quote
Old   January 26, 2011, 08:15
Hi Oliver,
thanks for your reply. Somehow Im a bit confused as Im not comfortable with this macro stuff.
Let's say the files I have are:
Version_01.sim
Version_02.sim
Version_03.sim
Do I than to open Version_01.sim, click the marco file button to generate a java file and put the text below??
package macro;
import java.util.*;
import java.io.*;
import star.vis.*;
import star.flow.*;
execute0();
try {
null, e.toString()
But were would the connection to the Version_02.sim and Version_03.sim be?
Im confused. Please advise.
Thank you!! again
Old   January 26, 2011, 09:00
Oliver Lauer
You create a file run.java containing the posted text with an editor of your choice.
Then you prepare all your simulation cases in a way that they only need to be started and save them.
At last you create a batch file where you write something like
starccm+ -batch run.java Version_01.sim
starccm+ -batch run.java Version_02.sim
starccm+ -batch run.java Version_03.sim
The details for this batch file depend on the OS you use. Usually you can see in the GUI how CCM+ is started on your machine.
run.java automatically finds out path and name of the simulation, runs it and saves the results with the same name.
Old   January 26, 2011, 10:05
Ryne Whitehill
rwryne is on a distinguished road
Alternatively you can look into a queuing system, which is external to STAR-CCM+.
e.g. : http://www.platform.com/workload-man...ance-computing
I am sure you can find some free/open source project to do the same thing.
rwryne is offline   Reply With Quote
Old   January 27, 2011, 13:00
WhoAmI is on a distinguished road
Originally Posted by Dora View Post
Hi everybody,
Regards,
Dora
If it is a simple problem i.e. varying velocity at the inlet or temperature on a wall at regular intervals, you can write a field function using floor or ceil functions and autosave option.
WhoAmI is offline   Reply With Quote
Old   July 13, 2022, 12:09
Marc Ricart
cramr5 is on a distinguished road
Hello, any update on that? does this still works on 2022.1 or similar versions?
I cannot manage to make it run. I can execute the program but does not open the window and then I cannot manage to make it run the simulation.
I'm on windows 10 if that helps
Thanks
cramr5 is offline   Reply With Quote
Old   July 14, 2022, 01:18
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Previously to do a batch run we have to set up a micro. We can still get batch run macro from Star-CCM+ support. But now Star-CCM+ have added node under "Tools" called "Simulation Operations". With simulation operations you can design your own algorithm from set of commands like meshing, running physics, setting different parameter value, clear solution etc. Try exploring this option.
ashokac7 is offline   Reply With Quote
Old   July 14, 2022, 03:20
Marc Ricart
Thanks but as far as I can see the "Simulation Operations" is only allowing you to do some automated options within the same simulation (*.sim) file.
What I would like to do is to prepare like 3-4 *.sim files and execute them one after the other automatically. I only have 1 power license and this way would allow me to run various 3-4h simulations overnight
Old   July 17, 2022, 23:00
cwl
Chaotic Water
cwl is on a distinguished road
The simpliest way I can see - is to use the command line.
cwl is offline   Reply With Quote
Old   July 18, 2022, 04:38
f-w
f-w's Avatar
f-w is on a distinguished road
As others have suggested, command line is the best approach. Here's how you do it in Windows 10 using 2022.1.1 (17.02.008):
1) Make sure your sims have batch autosave enabled (in File>Autosave).
2) Place all your sims and macros in the same folder.
3) Create a text file that contains the following text, and rename its extension from .txt to .bat
If you have macros you'd like to run for each sim, use:
"C:\Program Files\Siemens\17.02.008\STAR-CCM+17.02.008\star\lib\win64\intel20.1vc14.2\lib\s tarccm+.exe" -power -np 2 -batch Sim1.java Sim1.sim
"C:\Program Files\Siemens\17.02.008\STAR-CCM+17.02.008\star\lib\win64\intel20.1vc14.2\lib\s tarccm+.exe" -power -np 2 -batch Sim2.java Sim2.sim
If you don't have macros for each sim and just want to run till stopping criteria, use:
"C:\Program Files\Siemens\17.02.008\STAR-CCM+17.02.008\star\lib\win64\intel20.1vc14.2\lib\s tarccm+.exe" -power -np 2 -batch run Sim1.sim
"C:\Program Files\Siemens\17.02.008\STAR-CCM+17.02.008\star\lib\win64\intel20.1vc14.2\lib\s tarccm+.exe" -power -np 2 -batch run Sim2.sim
NOTE: for some reason, a space is introduced in starccm+.exe in the quotes above, remove it.
4) Change 17.02.008 to your version (if different), installation directory (if different), the number after -np for the number of cores you want to use (note: these are all on local host), and obviously the names of macros and sims.
5) Open command prompt and change directory to your folder. This is easiest done by opening the folder, clicking in the address bar, typing cmd, and hitting enter.
6) Run batch file by typing its name and hitting enter.
7) If you want to terminate current sim or whole batch job, press Ctrl+C. If you want to view current sim, open Star-CCM+, right-click on your sim in Servers window and connect (then disconnect when done).
f-w is offline   Reply With Quote
Old   July 18, 2022, 04:52
Smile
  #12
Marc Ricart
Wow you are amazing! that works perfectly, thanks a lot, you saved me from having to connect from home to save and start new simulation during nights and weekends! got a beer paid if you come to Barcelona
To be fair, I managed to execute it and I saw starccm was running on the task manager but I didn't know what it was doing... the connect to the server I did not know and that all now makes sense.
Old   July 18, 2022, 06:10
cwl
Chaotic Water
I'd suggest using Simulation Operations - many (but not all) things can be automated within single simulation via that tool: saving simulation, exporting scenes etc.
Old   July 18, 2022, 10:08
Marc Ricart
thanks, you are right, that looks like a powerful tool to automate things
Old   October 21, 2022, 18:13
Pinx is on a distinguished road
I'm using Stra-CCM+ 17.02.008-R8 version and I can't get it to work with this batch file.
"C:\Program Files\Siemens\17.02.008-R8\STAR-CCM+17.02.008-R8\star\lib\win64\intel20.1vc14.2-r8\lib\starccm+.exe" starccm+ -server -power -podkey MYPODKEY -licpath 1999@flex.cd-adapco.com -np 2 -batch run Star.sim
I open command prompt and go to the folder where I have the batch file and simulations and run the batch file.
I always get this error message:
Unable to start Simcenter STAR-CCM+.  Invalid file type.  Check arguments and their order.
Usage: starccm+ [-server] [<options> ...] [<simfile>]
Can anyone please tell me what am I doing wrong?
Pinx is offline   Reply With Quote
Old   October 22, 2022, 20:12
f-w
f-w's Avatar
Looks like you copied the command from the GUI. If you compare your command to the example I posted, you'll find the difference (starccm+ -server is not needed, and -licpath 1999@flex.cd-adapco.com is not needed unless you're overriding the default with something else). See more info in the help file under Client-Server Setup > Command-Line Reference.
Before:
After:
C:\Program Files\Siemens\17.02.008-R8\STAR-CCM+17.02.008-R8\star\lib\win64\intel20.1vc14.2-r8\lib\starccm+.exe" -power -podkey MYPODKEY -np 2 -batch run Star.sim
Old   November 17, 2022, 04:54
Marc Ricart
One question, If I have a Macro that will be called during the batch operation, when that macro will be called exactly? after all the "simulation operations" actions are finished or when exactly? is there a way to define it?
Also, can I add a "Simulation Operation" that calls a Macro? this way I can control when each macro is executed.
Thanks
Old   November 17, 2022, 16:41
f-w
f-w's Avatar
Thanks
The batch macro is called when launching the simulation. Whatever you do in the macro is what's done to the simulation. The batch process (in this case) does not automatically run, mesh, or save; so, the macro must do this (except saving, you can also do this automatically via a tick mark in File>Autosave).
The macro you pass to the batch process can call other macros & execute sim ops (which themselves can call macros). It's macros all the way down, yo. So, in your case, just have the batch macro execute your sim op.
There's also a "run" batch command; however, it's equivalent to hitting run, and I don't think it executes sim ops (never tried it).
Old   November 18, 2022, 08:05
Marc Ricart
You mention that you can execute Macros with Simulation Operations? I don't see the option in there.
Old   November 18, 2022, 15:21
f-w
f-w's Avatar
That was a misunderstood agreement with your question ("can I add a 'Simulation Operation' that calls a Macro?"). Since I never used sim ops, I thought your question implied that macros could be called by sim ops and you were asking if the batch macro could call such a sim op. Sounds like this is not the case, so my comment on this should be disregarded.
So, you must have been asking whether you can call macros within the batch macro itself? If so, then the answer is yes (as previously stated).
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 14:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
How to run InterFoam in steay state waynezw0618 OpenFOAM Running, Solving & CFD 0 November 10, 2008 08:08
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 17:36
Restatring run Tim CFX 2 March 3, 2006 12:54
