Sloshing frequency determination
Old   January 20, 2011, 23:40
Default Sloshing frequency determination
alastormoody11 is on a distinguished road
I am trying to determine the sloshing frequency in a cube.
I realize that one way to do this is to plot the variation of the force on the container, however there are two phases air and water that I am simulating and the walls have been modeled as one part, how accurate would the result be if I determine the sloshing frequency by applying a FFT to force variation as function of time which will include forces applied by both air and water.
The question is whether the force applied by air be so small that frequency will be obtained to a reasonable degree of accuracy?
alastormoody11 is offline   Reply With Quote
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 12:21
Will a multi-grid method damp out the high frequency physical wave? hadesmajesty Main CFD Forum 8 October 13, 2009 01:26
Backward FAcing Step - Frequency CFDtoy Main CFD Forum 8 October 29, 2006 21:51
Reasons for failed validation at high frequency zonexo Main CFD Forum 5 October 23, 2006 10:32
VOF Sloshing - beating pattern in force output? Brian FLUENT 0 May 18, 2006 11:59
