How to Refined mesh ?
Old   January 20, 2011, 16:24
Default How to Refined mesh ?
madhuri is on a distinguished road
Iam trying to generate a good meshing scheme for a nozzle. Attached is the mesh I generated in starccm+. I used customized polyhedral meshing for some important parts as can be seen in the figure.
However, I am concerned with the mesh size at the nozzle exit. At the centre of the nozzle, mesh size is bigger. How can I make is smaller?
I used a base size of 0.5mm and 10% of the base size for some parts. Even though i decrease the relative mesh size of the nozzle parts, mesh size at the centre of the nozzle doesnt reduce. If I reduce the base size, meshing takes forever to generate. Therefore, i wanted to adjust the relative mesh size for the nozzle area.
Can some suggest me how to achieve this.
FYI, Iam trying to simulated choked flow (water) in the nozzle. Operating conditions, Inlet Press = 25MPa, T=633K and outlet P = 10 MPa.
Thanks
madhuri is offline   Reply With Quote
Old   January 20, 2011, 23:31
alastormoody11 is on a distinguished road
You can use the volumetric controls, firstly generate a cube or a sphere and then you can independently set the parameters just for that volumetric region that you created like a different minimum size etc.
Hope that helps
alastormoody11 is offline   Reply With Quote
Old   January 21, 2011, 20:37
abdul099 is on a distinguished road
When you just want to get more or less uniform cell sizes on a boundary, you can also set the same value for minimum and target size on that boundary.
abdul099 is offline   Reply With Quote
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 18:31
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
