How to find center of pressure
Old   December 22, 2010, 20:02
Question How to find center of pressure
cfdnewbie1 is on a distinguished road
I've done a simulation of a sample car body, and I would like to evaluate the distribution of aerodynamic forces between front and rear of the car.
To do so I need to know the position of the center of pressure.
I've read in this forum and it seems that with Fluent you can do this simply with a report, I couldn't find nothing similar in Star-ccm. Is it right?
In a previous post I've found that you can use the surface integral report to calculate the coordinates.
I've defined three user field functions like this:
$$Position[0]*$Pressure (for X direction)
surface integrated this and divided by the surface integral of Pressure.
I've found three coordinates that seems good, but if I calculate a moment defining this coordinates as origin of my axis I found non zero moments as expected.
What is wrong?
There's a simpler procedure to find the center of pressure location?
Thank you everybody for your help.
Regards.
C.
cfdnewbie1 is offline   Reply With Quote
Old   January 6, 2011, 17:59
abdul099 is on a distinguished road
Why don't you create a force report and a moment report? You can easily calculate it by hand.
abdul099 is offline   Reply With Quote
Old   February 11, 2011, 12:21
Luke
Chonker is on a distinguished road
I have a similar problem, how is this calculated by hand, I have a Moment about Y (horizontal) and a Force in X (drag longitudinal) and Z (lift vertical). This gives me an equation with two unknowns in (the distance x and z from the origin that the forces act).
Drag*z - Lift*x = Moment
Is this right? How can the two unknowns be solved?
Chonker is offline   Reply With Quote
Old   February 16, 2011, 10:52
and_ is on a distinguished road
You create a Momentum coefficient report.
As the Axis Origin you use e.g. the front tire.
As the Reference Radius you use the distance between front and back tire.
You don't need to know the center of mass or pressure since you cut at the tires.
That is the momentum doesn't act around the the center of mass or pressure, but around the front tire's contact with the ground
and_ is offline   Reply With Quote
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
how to find center of press. loc. Xcp of 3d body? taimoor FLUENT 1 February 21, 2009 11:06
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
