Help with parallel exec on Intel i7
Old   November 25, 2010, 09:35
Question Help with parallel exec on Intel i7
cfdnewbie1 is on a distinguished road
Hello to everybody,
I'm a complete newbie with CFD and Star-CCM+.
I'm trying to learn something on this software thru tutorials and examples.
I have the following problem: when I start Star-CCM+ in parallel mode I get the following warning:
Starting local server: starccm+ -server -np 2
Worker Node[2]@XXXX process 692 (MPICH2:nemesis)
Master Node[0]@XXXX process 5460 (MPICH2:nemesis)
STAR-CCM+ Version 4.04.011 (win64/intel10.1)
Worker Node[1]@XXXX process 5404 (MPICH2:nemesis)
Server::start XXXX:51786
Disabling parallel asynchronous communications.
STAR-CCM+ will avoid using non-blocking communication. This may degrade the performance.
My machine is a laptop with a intel-i7 Q720 (4 core - 8 threads), I use Windows 7 64 bit, and MPICH2 ver. 1.3.
My question is: is there a way to configure MPICH2 or Star to use the parallel asynchronous comms? How much does this have an impact on performance?
Thank you very much for your help.
Regards
cfdnewbie1 is offline   Reply With Quote
Old   November 29, 2010, 15:25
f-w
f-w's Avatar
f-w is on a distinguished road
It has a small but measurable effect. There's a checkbox in Tools>Options>Parallel> that you can change.
f-w is offline   Reply With Quote
Old   November 29, 2010, 15:55
thank you very much! i will do some benchmarks.
Old   December 1, 2010, 09:58
fastwave is on a distinguished road
What are the disadvantages of using the asynchronous?
cfdnewbie1, I would be interested on the bechmark times. If you can pst them when done that would be appreciated.
fw
fastwave is offline   Reply With Quote
Old   December 23, 2010, 08:27
Here the results of the benchmark done with the bluntbody.sim tutorial.
4 cpus
Enabled
Solution
Accumulated CPU Time over all processes (s) 6007.063
Elapsed Time (s) 1506.699829
Iterations 1500
Disabled
Solution
Accumulated CPU Time over all processes (s) 6178.668
Elapsed Time (s) 1550.230431
Iterations 1500
Old   December 25, 2010, 05:34
filippo
filippo.aero is on a distinguished road
hello, just a simple information: I'm trying to do the same on an i7, but star-ccm replies with "no MPI distribution found", even if I installed mpich2. How did you get it to work? I mean, first installed star, then mpich, etcc
filippo.aero is offline   Reply With Quote
Old   December 27, 2010, 11:07
You have to start the set the mpich process to start automatically.
try to google
smpd.exe –install
mpiexec.exe –register
you can find all the info!
Hi
intel i7, mpich2
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
AMD X2 & INTEL core 2 are compatible for parallel? nikolas FLUENT 0 October 5, 2006 07:49
