October 22, 2010, 12:25 |
slip wall conditions
ahmad bakri
Rep Power: 16 |
hey all,
i am simulating a process where an interface on a surface has full sticking conditions with a rotating cylinder, this will generate heat ...and then I find the temperature distribution over that surface. now the tool is fixed and rotating, and the surface is modeled as flowing fluid with slip conditions except at the interface, as I increase the velocity inlet speed a tail behind the interface with the cylinder appears and it becomes longer with higher speeds. but the maximum temperature in the interface zone never changes, it reaches always the same values, so does any body knows what to do with slip wall conditions to let the temperature changes at the interface? thanks |
moving and slip wall boundary | hongchun | FLUENT | 4 | July 9, 2010 12:29 |
microfluid: slip wall condition | hoola | FLUENT | 1 | July 5, 2009 11:37 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Confusion about the wall oundary conditions. | windhair | CFX | 0 | August 13, 2006 15:18 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
