September 23, 2010, 09:25 |
Unable to boolean substract
This is what I have done so far:
I imported my model as a part. Then I made another part in the 3D-CAD model manager and combined this with the imported part. I then made a region out of the combined part. Then I created a block surface which was going to be my fluid domain. Why can't I do a Boolean substract with these two regions? |
September 23, 2010, 12:37 |
John
Rep Power: 17 |
Why are you trying to subtract the combined part from the region?
September 24, 2010, 09:41 |
Oliver Lauer
Rep Power: 17 |
You have to initialize meshing before doing a boolean subtract.
September 28, 2010, 03:27 |
Apparently, what I was trying to do isn't possible in this (the newest) version. Will be possible with the next version which is due sometime in October/November.
Everything is sorted though. Just had to import every part as a region into a new .sim file. |
October 2, 2010, 15:33 |
Rep Power: 21 |
You can't subtract regions if you don't have an "initial surface" representation. You will get this representation when you initialize the meshing pipeline, and after that you can do a boolean subtract - even when importing geometry as a part.
Cheers |
Sun Grid Engine | grtabor | OpenFOAM Running, Solving & CFD | 28 | August 22, 2012 09:27 |
openfoam 1.6 on debian etch | romant | OpenFOAM Installation | 9 | May 6, 2010 02:26 |
fluent | nithin20k | Main CFD Forum | 1 | January 12, 2010 19:37 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
volume substract causes gaps, unable to mesh | Ron | FLUENT | 0 | June 20, 2005 19:03 |
