July 15, 2010, 09:18 |
Simulating bubble rise
Marti J
Rep Power: 16 |
Hey,
I would like to know, if it is possible to calculate only the bubble rise movement inside a liquid column. The case is that I ran the calculation for liquid flow in the beginning, to get the steady state values. Now I need to inject bubbles and calculate their terminal velocities in the pre-found flow field. It takes a lot of resource to run the flow all the time again, so could I just run the bubbles (Lagrangian phase) separately? Thanks in advance! |
July 15, 2010, 17:54 |
Tom Keheley
Rep Power: 16 |
Why not use Volume of Fluid - or as CD-Adapco calls it now, MultiFluid? If there isn't any heat / mass transfer between the phases it should be easy to do.
July 16, 2010, 04:55 |
Marti J
Rep Power: 16 |
I think that the injectors are really useful and convenient anyway to use. If I'll do it in MultiFluid way, I think it wouldn't be more suitable and then one needs still to calculate the whole flow field over and over again. Just need to change the diameter of a bubble, run the case (without running the bulk flow again), change the d again etc..
July 21, 2010, 11:18 |
Rep Power: 16 |
You can freeze solving the flow field by setting the AMG solver Max Cycles for Velocity and Pressure to 0.
Don't use the Solver Frozen option or you might get problems with unallocated variables |
Bubble rise velocity in Fluent | Xilaf | FLUENT | 28 | January 14, 2013 02:10 |
bubble rise velocity | Xilaf | FLUENT | 0 | March 8, 2010 04:02 |
bubble rise velocity | Xilaf | Main CFD Forum | 0 | March 3, 2010 16:01 |
Problem simulating bubble formation in microchannels | iitian2005 | FLUENT | 0 | June 3, 2009 03:03 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
