June 8, 2010, 12:29 |
Meshing error
Matt Lynam
Rep Power: 16 |
I am getting an error when attempting to re-mesh my surface and create a volume mesh. The error reads:
orientFaces: Sidedness had an error has anyone seen this error? I am running version 4.06.011 and using the polyhedral, prism layer, and surface remesher for the model. Any help would be appreciated. ML |
June 8, 2010, 16:01 |
Vinicius Girardi
Rep Power: 17 |
Check if your imported surfaces doesnŽt have pierced faces or other errors. Maybe youŽll need to use the surface wrapper tool.
June 8, 2010, 17:20 |
Matt Lynam
Rep Power: 16 |
I did inspect the original surface and I couldnt't find any pierced or strangley formed geometry. Also - surface wrapper is out of the question as I have multiple regions in the geometry. Thank you for your reply, do you have any other ideas?
ML |
June 8, 2010, 18:06 |
Vinicius Girardi
Rep Power: 17 |
You said you have multiple regions, are they already set or you will split by surface topology to create the interfaces?
June 9, 2010, 12:20 |
Matt Lynam
Rep Power: 16 |
They are already set and the interfaces have been created.
ML |
June 9, 2010, 13:07 |
Rep Power: 17 |
The wrapper can be used on multiple regions if "per-region meshing" is checked in your mesh continua; you won't have a conformal mesh at the interfaces as a result, though.
June 9, 2010, 17:55 |
Matt Lynam
Rep Power: 16 |
Ah! I have a mesh. Thank you for your help everyone!
ML |
July 6, 2010, 09:47 |
Rep Power: 21 |
Maybe you want to tell us what the cause for the problem has been? It could also help other users with a similar problem...
Best regards, |
July 8, 2010, 13:16 |
#9 |
Matt Lynam
Rep Power: 16 |
abdul099,
I believe I was having the issue because I was applying a single mesh continuim to multiple regions. When I applied the "per-region meshing" option I no longer had the problem. Does that help? ML |
November 29, 2011, 15:47 |
#10 |
Rep Power: 14 |
@ Mlynam and abdul099
yes that was the reason. I had the same problem as u abdul099. I activated "per-region meshing" and now star ccm+ mashed. thank you so much! greetz |
January 2, 2012, 14:29 |
#11 |
Per region meshing works but if I would like a conformal mesh at the interfaces this will not suffice.
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 | silent_missile | OpenFOAM Installation | 5 | August 10, 2007 07:31 |
