user field function
Old   May 12, 2010, 12:51
Exclamation user field function
Girish Gaikwad
girishg is on a distinguished road
I want to define new variable {(velocity:Ycomponent)/(free_stream_velocity)}. But in system defined field functions I am not able to find function called velocity:Ycomponent. It is only showing velocity which is a vector quantity. How can I make all components of velocity visible in field functions tab? Please help me.
I searched on help menu and got this: System field functions are predefined field functions that are created by the models activated in the continua, and share a particular set of properties.
How can I activate velocity components and magnitude?
girishg is offline   Reply With Quote
Old   May 12, 2010, 15:15
Pete Launie
plaunie is on a distinguished road
Velocity vector components are:
$$velocity[1]
$$velocity[2] <--velocity:Ycomponent
$$velocity[3]
plaunie is offline   Reply With Quote
Old   May 12, 2010, 18:41
Girish Gaikwad
Thanks a lot.
But what is the syntax(definition) for free stream velocity that can be used in the above formula? And also it doesn't show the three components of velocity in field function tab (one of the example in help window showed velocity as well as its three components).
Old   May 12, 2010, 21:24
Pete Launie
Originally Posted by girishg View Post
Thanks a lot.
Question: are you trying to get the velocity magnitude, or velocity at a freestream boundary?
for local velocity magnitude:
I don't know off the top of my head, but Velocity is a vector so...
sqrt($$velocity[1]^2+$$velocity[2]^2+$$velocity[3]^2) if nothing else.
I think there is a velocity magnitutde field function something like $velocity.magnitude, or mag($$velocity). I'm not sure I don't have access to the documentation at the moment.
For boundary velocity it's probably just easier to enter the velocity. i.e.
$$velocity[2]/12345
Old   May 12, 2010, 22:32
Vinicius Girardi
Vinicius is on a distinguished road
for velocity magnitude, use mag($$Velocity) and for Y direction, use $$Velocity[1]. The directions X,Y,Z are represented by [0],[1],[2] respectively.
Vinicius is offline   Reply With Quote
Old   May 13, 2010, 10:21
Girish Gaikwad
Thanks a lot guys!!!
field function
mean, variance and covariance statistics of any field function on any part. Subhadeep STAR-CCM+ 8 February 18, 2010 18:19
User Field Function hannow STAR-CCM+ 3 November 24, 2009 21:20
How to create an user defined function? Cagdas FLUENT 1 September 5, 2007 21:02
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
custom field function greg FLUENT 2 May 23, 2006 11:42
