April 29, 2010, 20:54 |
STARCCM+ and SYSNOISE
John
Rep Power: 17 |
I read the following in the v4.06 manual regarding STARCCM+ and SYSNOISE:
.CCM -- If you select the .CCM format, you can tick the Append to existing file checkbox to add the exported information to a .ccm file that you select. For example, this format can be read by FFT/ACTRAN and LMS/Virtual.Lab, which can be used in noise propagation cases. Is this true or is a separate plug-in required to export in the cgns format that is compatible with SYSNOISE? Thanks. |
aeroacoustics, cd-adapco, noise, starccm, sysnoise |
