help with Baffles...
Old   April 26, 2010, 16:32
Default help with Baffles...
syd
Mattia
syd is on a distinguished road
Hi everyone!
I am simulating a sailboat, with a mainsail and a jib: I managed to create a mesh that satisfies me, but it's huge(8 millions of cells of volume mesh), so I'm trying to reduce it; one way I read about was "transforming" the sails in baffles interfaces.
Untill now, I imported the 2 sails in CCM as .IGES files, with a thickness of 0.4 mm: in this way, everything works, but the resulting mesh is huge, as I said before, because of the very small thickness.
So, I tried to import them as superficies, with no thickness (as .IGES files): the software allow me to import them, but it warns me that they "are not solid": in fact, as I try to perform a boolean union (between the hull+mast+boom and one sail) I get an error message "not closed and manifold region", referring to the sail.
My question is: how do I handle my boundaries:
-mainsail
-jib
-boat
-wind tunnel
if I want to turn my 2 sails in 2 baffles with no thickness?
thanks to everyone!!!
syd is offline   Reply With Quote
Old   April 26, 2010, 17:06
kyle is on a distinguished road
You are not going to be able to mesh the sail as a baffle in Star-CCM+, at least not easily.
You can try meshing the same way that you originally tried, but disable proximity refinement in the mesher. This way it will not create tiny cells all over the sail.
kyle is offline   Reply With Quote
Old   April 27, 2010, 18:36
Vinicius Girardi
Vinicius is on a distinguished road
Before meshing, right click at the boundary that have your "only surface" sail and click in convert to interfaces. Keep both in the same region, and in the node called interfaces, change the interface type from Internal Interface to Baffle interface. This allows you to generate a mesh without no manifold edges.
Try to see where these non-manifold edges are in your model, in the surface repair mode. They will be the blues edges.
Always check your surface to see if it has non-manifold edges/vertices, free edges and self-intersections.
Vinicius is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Including baffles in automatic meshing(pro amm) Ankush Aggarwal Siemens 2 June 28, 2006 03:24
Loosing baffles while creating a volume mesh Susanne Siemens 0 May 9, 2006 03:52
Mesh problems for a stirred vessel with baffles! UY CFX 0 September 14, 2005 11:19
