April 12, 2010, 05:49 |
Calculating outlet temperature pipeline
Greetings!
Background: I am utilizing CCM+ as part of a college level project, and I have very limited experience with CCM+, infact I have barely had time to finish some of the tutorials and have fooled around with the program for a bit in order to familiarize myself with it. My apologies in advance if the following is something I should have figured out myself, but I didnt and hence seek some guidance from this forum. Problem: I am trying to simulate seawater flowing through a buried pipeline in a hot climate, and wish to calculate outlet temperature, as a result of heat conduction through the soil and pipeline. I have generated what seems to be a solid mesh and applied adiabatic walls at a given distance from the pipe wall, with a fixed convection rate from the surface to simulate heat transfer from radiation and convection - this is obviously a very simplified approach, but as stated I do have very limited CFD experience.. Now what seems to be the problem for me is choosing the appropriate physics models to the continua, because as it is I am unable to choose Temperature as an output as was done in the "heated fin" tutorial. Is CCM+ actually able to solve for temperature in such a simulation (3-d, fluid surrounded by multiple layers of solid), and if not do you have a suggestion for an alternative approach to the problem? My goal with the simulation is to verify a theoretical model used to estimate outlet temperature in a long pipeline. This estimation will be rough, and not account for change in ambient temperature etc. Thank you in Advance. Erik |
April 12, 2010, 10:41 |
Vinicius Girardi
Rep Power: 17 |
How are you trying to measure the temperature? Is it an Area averaged report from the outlet?
April 13, 2010, 06:45 |
Thank you for your swift reply.
Ideally I am looking for an output similar to the one from the heated fin tutorial - I would guess an area averaged report from the outlet would suffice to estimate the average outlet temperature after a given distance. Again I apologize if the question may seem trivial, but this is due to my lack of experience with CFD. Erik |
April 14, 2010, 09:41 |
Lin Möllenhoff
Rep Power: 16 |
right click on Report, new Report, Area Averaged.
rename it as you like in the property window you chose scalar: temperature parts: your outlet boundery units: C or K right klick on your new report: run report: your value will be displayed! you can also create a monitor from your report to save your report value at each iteration! |
relative humidity and temperature by outlet | Bing | FLUENT | 5 | March 7, 2014 06:03 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Setting of the outlet temperature | Chinna | FLUENT | 0 | November 29, 2003 12:42 |
Question on checking incell temperature at outlet | Guoqing | Phoenics | 1 | June 4, 2003 17:50 |
