turbulence model for separated flow in diffuser
Old   March 2, 2010, 03:08
Question turbulence model for separated flow in diffuser
R Martis
Martis is on a distinguished road
Hi
I am simulating 3D compressible flow in a diffuser (Mach number =4) ...The CCM+user manual says that SA model is not appropriate for separated flows. I have tried SST K-omega and realizable k-epsilon (RKE) models as well. SST K-omega does not start the diffuser...however, RKE does work. But shows huge separated regions at the exit. SA and RKE show similar separation patterns and pressure distibutions near the diffuser contracted regions. the main difference in the 2 models is at the exit.
I am unable to decide which of these models, SA or RKE, is more reliable in my study. A couple of other softwares, like NUMECA, give good results with SA for separated flows as well. Can the same be applicable with CCM+ also?
Please advice.
Martis is offline   Reply With Quote
separated flow, turbulence
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 12:42
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence model for oil flow thr' small gap carno Siemens 2 August 31, 2005 09:12
Turbulence Model for flow between corotating disk Felipe FLUENT 0 January 10, 2004 13:01
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
