Looking for suggestions about how to set up a boundary condition |
February 25, 2010, 18:08 |
Pete Launie
Rep Power: 16 |
I would like to model a multi-component gas flowing over a membrane which allows one of the components to diffuse through it. Not sure how to set up the problem in star ccm.
can I define a boundary with a negative mass flow based on a field function which looks at the local mass fraction of that gas component? Is this asking for trouble or does anyone have other ideas about how to set it up? Thanks for your help. |
February 28, 2010, 14:14 |
Naimish Harpal (MS Aerospace Engr)
Rep Power: 17 |
Regrading your membrane BC, to diffuse multi-component gas, you can define that boundary as 'Pressure Outlet'. Then define pressure and the mass-fraction (between 0 and 1 w.r.t to total mass-fraction) of particular gas to be sucked out. You may calculate the pressure in terms of velocity and mass flow rate using simple Bernoulli' equation.
I hope that this may help you. |
March 23, 2010, 16:12 |
#3 | |
Pete Launie
Rep Power: 16 |
April 6, 2010, 14:08 |
Update
Pete Launie
Rep Power: 16 |
CD-adapco said there is no way to specify a per species boundary condition and trying to come up with a work-around.
boundary conditions, star ccm+ |
how to set boundary condition for a tank filling w | namrata | FLUENT | 6 | May 2, 2007 11:23 |
Rotating interpolated boundary condition | hani | OpenFOAM Running, Solving & CFD | 0 | July 4, 2006 08:09 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
how to set the porous boundary condition | chocheng | FLUENT | 2 | March 22, 2001 14:42 |
how to set boundary condition about porous zone | chocheng | FLUENT | 1 | March 21, 2001 21:02 |
