Baffle meshing problem with polyedral mesher
Old   February 12, 2010, 07:29
Default Baffle meshing problem with polyedral mesher
Fex
Felix
Fex is on a distinguished road
Hello!
I'm having this problem:
having a baffle floating in the same continua i define it as an interface and then go trough the volume mesh
when i initialise the run it tells me that the baffle interface is invalid because all the cells spans both sides of the interface. This happens only with the polyedral mesh (no problems found with a tethraedral volume mesh)
can someone help me? I cannot run it on tethraedral as the cell count is 5 times more.
TNX
Fex
Fex is offline   Reply With Quote
Old   April 14, 2021, 10:32
Georg
kiteguy is on a distinguished road
Originally Posted by Fex View Post
Hello!
TNX
Fex
Hey, I realise this post is already from long ago, but I am facing the same problem now and was wondering if you or someone else knows a solution to it now?
Warning message:
The following potential issues were identified while verifying initialized interfaces.
============================= Interface Initialization Warnings =============================
1. Interface [ interface1 ] has invalid topology.
33 cells span both sides of the interface.
EDIT: I found out that the definition of a baffle interface is not required when not modeling heat transfer. Removing the interface and simply defining the two sides of the baffle as adiabatic walls fixed the initialization issue.
kiteguy is offline   Reply With Quote
baffle, cell, interface, polyhedral mesh, sides, span
Meshing problem Sanjay Jain FLUENT 6 April 5, 2008 10:51
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 09:29
3D-gambit meshing problem prem FLUENT 3 February 28, 2006 03:42
Baffle cell problem in shock tube AB Siemens 4 November 15, 2004 09:44
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
