Massflow report/monitor in CCM+
Old   December 28, 2009, 13:31
Default Massflow report/monitor in CCM+
Erez Raviv
erazz is on a distinguished road
I'm simulating a radial impeller. I've modeled a single channel with periodic BC's and so far I'm getting very good results. The simulation converges quickly, the velocities and pressures are right but the massflow is about 1/100 if the expected values.
Even when I use a massflow inlet and specify the correct flow the report shows low values.
I'm pretty sure that the results are physical but I'm doing something wrong while creating the report/monitor.
Any ideas?
erazz is offline   Reply With Quote
Old   December 29, 2009, 03:36
Joern Beilke
JBeilke is on a distinguished road
Check the size of your domain. Maybe there is something wrong with meters and feet.
JBeilke is offline   Reply With Quote
Old   December 30, 2009, 10:34
Erez Raviv
Hi beilke,
I've checked and the domain is fine. The speeds and pressures are also fine.
Is the massflow averaged over the entire patch or is it indicative of only one cell?
Old   December 31, 2009, 03:30
Erez Raviv
Solved it!
I was using area averaged and not massflow report.
impeller, periodic, radial
calculate MASSFLOW for a component MAldaz CFX 1 November 7, 2007 12:41
error in star ccm maurizio Siemens 3 October 16, 2007 06:17
massflow outlet in flunet. shrinath FLUENT 0 September 3, 2007 10:40
re: Massflow reset in CFX 10 Wooster CFX 5 March 16, 2007 21:08
about the massflow rate boundary condition whitemelon FLUENT 0 June 3, 2006 06:44
