reg Porous two phase flow simulation
Old   December 21, 2009, 03:07
Default reg Porous two phase flow simulation
chittoorreddy
chittoorreddy is on a distinguished road
Dear friends:
I am trying to simulate the dust in Air filter with Lagrange multiphase model with porous media approach for filter media.
In this my main aim is to see the dust distribution over the filter media based on dust particle size and the rise in pressure drop due to accumulation of dust.
My doubts are
1) is it possible to simulate the pressure drop due to accumulation of dust using Lagrange multi phase model?
2) How these particles interact with porous media?
3)Is it possibe to simulate by increassing the porous coefficients the filtering capacity??
if anybody already did this kind of simulations kindly share the same wiht me. it will be a very very helpful for me
With thanks in Advance,
Sreenivasulu Reddy
chittoorreddy is offline   Reply With Quote
Old   December 21, 2009, 06:37
TonyD
bramv101 is on a distinguished road
No this is not possible, what you can do is apply test data and alter your viscous and inertial coeff manually, seeing the effect of flow distribution
you can simulate these type of things when you do this on microscopic level, with your own usercode. otherwise i would say forget it
No idea what you entirely mean with this. But no, altering the porous coefficients will not have any effect, and for sure this will not be very realistic, Only clogging test data should be used to see effect on flow distribution.
In short: start reading up on CFD for filtering applications because these questions tell me you have a long way to go and you probably will start off wrong. This is certainly one of the more challenging CFD problems. try to contact companies such as Donaldson which are world leader in this. Mann+Hummel is more automotive but without the same level of media research.
bramv101 is offline   Reply With Quote
air filter, multi phase, porous
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
Discrete phase model in porous media Pradeep FLUENT 0 February 3, 2006 17:30
Two phase Flow instability shaoping Main CFD Forum 1 September 8, 2003 14:25
Simulation of Porous Media Flow Sharad Dugad FLUENT 0 December 24, 2001 02:57
