Starccm+ Java.net exception
Old   December 10, 2009, 15:21
Default Starccm+ Java.net exception
vsumanth10 is on a distinguished road
I am facing some issues with StarCcm+ 4.04 in my setup. I have installed Starccm+ 4.04 on my DELL Precision T7500, which has RHEL 5.2 64 installed. Everything works fine on the default kernel of RHEL 5.2. I upgraded the kernel from kernel-2.6.18-92.1.17.el5 to kernel-2.6.18-164.6.1.el5. Now, after starting a new simulation (file->new), the import option in the file menu (file->import) is disabled. The problem happens when logged in via ssh or the console. When using ssh, a java.net ConnectException appears after a minute: "java.net ConnetException: Connection timed out:" Please find attached the screen shot of the java exception and a file which has the details of the exception. Can somebody explain me what is going on and help me figure out a solution???
Thanks in advance!!!
Sumanth
vsumanth10 is offline   Reply With Quote
Old   April 27, 2010, 04:28
Manuj
Manuj Vyas is on a distinguished road
I also faced similar problem but could not get any solution . I m trying to contact cd adapco personally . May be i will get the answer within 2 or 3 days . Will post the answer later.
Manuj Vyas is offline   Reply With Quote
Old   April 27, 2010, 18:39
Vinicius Girardi
Vinicius is on a distinguished road
Do you have the required version of java installed on both computers?
Try to garantee that your version is the recommended one. It is always good.
Vinicius is offline   Reply With Quote
Old   April 29, 2010, 04:17
Oliver Lauer
olauer is on a distinguished road
Be careful with JAVA updates on Windows. CCM+ 5.02 went back to Java6 Update7(!) (only on Windows!) because newer versions show problems with DirectX (see Installation Guide)
olauer is offline   Reply With Quote
[Other] Problems with starccm mesh AndTen OpenFOAM Meshing & Mesh Conversion 1 February 23, 2010 05:43
Importing new design in starCCM bramv101 STAR-CCM+ 0 October 1, 2009 09:43
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
"exception : return code 139" june Siemens 0 January 8, 2008 21:20
Meshing Errors in Starccm Josh Kempenaar Siemens 2 November 30, 2006 09:14
