December 7, 2009, 05:41 |
wrong values in thermal analysis
Francesco
Rep Power: 16 |
Hi to all people!
I'm contacting you for this reason: I have built a model that refers to a pipe that is covered by insulating material, I have used bidimensional surfaces to model isulation. I have made 3 simulation tests : -The first : with insulating surface at distance of 10 mm from heating source ( exaust pipe) where i assigned only emissivity (aluminium ) insulating surface -the second :where I moved surface to 5 mm from heating source and added thermal resistance (relative to Glass Fiber) - The third : only changed thermal resistance of insulating material changing it to a value that is 2 times greater than the material I used in the second test. My problem is that , in the first two simulations, I have obtained correct values in post processing relative to avarage and maximum temperature. But in the last one I have obtained a peak in some cells that are really out of range, so this influences my average and maximum temperatures, bring my simulation to totally wrong values. My model use about 800000 polyhedral cell. I used surface to surface radiation model , coupled flow for convection. Could It be a meshing problem? Maybe due to thermal resistance raised value? Anybody can help me ? Thank you guys... Francesco |
FSI Transient Thermal Analysis | Abduri | CFX | 1 | January 1, 2017 22:54 |
Transient Thermal Analysis with FSI | Abduri | CFX | 2 | March 27, 2009 02:47 |
thermal stess analysis??? | Jinfeng | CFX | 3 | January 15, 2009 07:00 |
thermal analysis free code | margarita | Main CFD Forum | 2 | January 7, 2008 13:14 |
Floworks: Mixing and thermal analysis of two gases | Jay Nelson | Main CFD Forum | 0 | June 14, 2005 18:29 |
