September 14, 2009, 04:34 |
Memory Exception Workaround?!
Rep Power: 18 |
I have serveral problem whit creating some meshes because this happens in only one process under windows.
Simulations are splitted because I have more cores but only 32Bit... Is there a trick to create the mesh on 2 processes? Mesh isn't very big, only 300MB but the task manager shows me that CCM needs much more memory for the volume mesh... and then I get a memory error (bad alloc). Import mesh looks nice, should I look for some faults? |
September 14, 2009, 05:37 |
TonyD
Rep Power: 17 |
i would say, check your mesh settings. Maybe there is a decimal point misplaced so your mesh size goes very fine. this is usually the cause of these type of problems.
A good tip is to do a surface mesh with coarse settings and examine results. from there add more detail |
September 14, 2009, 05:54 |
Rep Power: 18 |
The cell size is 1mm, base and maximum. Surface cell size the same. Should I make in coarse?
Maybe I should update to 64Bit... |
September 14, 2009, 06:46 |
TonyD
Rep Power: 17 |
The actual cell size doesn't tell me much, you should compare it to the dimensions of your part. if your part is 100 meters in diameter and your cells only 1mm then you are going to get a huge model.
Take for base size 5 percent of your main inlet orifice, and leave everything else at default. then try to do surface mesh NOT volume mesh. Check your mesh and if you notice that not enough detail is included, adjust your surface size max=100% and min=15% If you could post a rough sketch of your geometry and your base dimensions, this would be good to start from |
September 14, 2009, 07:23 |
Rep Power: 18 |
Ok I will look what I can do.
Dimension isn't very big, 1mm is a little bit to coarse I think. When I make a corse volume mesh I get problems with rasing the mass flow etc. |
September 14, 2009, 17:37 |
Rep Power: 18 |
I have checked all my settings. I had a extrusion of my wall. Don't know how it came... but it was set...
Thanks for help. |
SIGSEGV: memory access exception | shawn123 | STAR-CCM+ | 14 | January 20, 2020 07:07 |
How to optimize the memory usage when using FEM | vasilis | Main CFD Forum | 11 | August 25, 2009 00:57 |
Memory error? | Young | CFX | 3 | September 30, 2008 12:33 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 18:50 |
Run-Time memory conifguration Error | Graeme | CFX | 1 | February 21, 2006 00:04 |
