Importing Mesh from Gridgen to CCM+
Old   September 3, 2009, 05:55
Default Importing Mesh from Gridgen to CCM+
S M Khan
smkhan is on a distinguished road
hello,
May i know how can i import gridgen mesh into CCM+? what type of file format must i use to save in gridgen to achieve this? How can i do this in CCM+
thank you.
smkhan is offline   Reply With Quote
Old   September 6, 2009, 18:45
John Chawner
jchawner is on a distinguished road
Hello again. I just answered your similar question about going from Gridgen to STAR-CD. Since you also have questions about the native interface to STAR-CCM+, let me take another approach to this issue.
If you want to export solver-compatible files from Gridgen, you first choose the solver from the Select Analysis Software menu. Then, you look for the Export Analysis Data command. In the case of STAR-CCM+ you'll produce a file that STAR-CCM+ can read directly.
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   September 8, 2009, 02:49
Default importing mesh from Gridgen to CCM+
S M Khan
i have followed the steps as you have said. but, it is still not working. the part of choosing solver is ok. there is having problem in exporting part. so you please explain elaborately.
Thank you
Old   September 8, 2009, 09:08
Maddin is on a distinguished road
Is it much work in Gridgen to "clean" and "repair" the Import Surface?
I often have the problem that surfaces looks pretty nice in Catia etc. but in CCM I have many holes and interceptions. Often too much to repair it with CCM step by step...
Maddin is offline   Reply With Quote
Old   September 8, 2009, 09:14
John Chawner
S M Khan:
For an elaborate explanation, contact our Technical Support team at support@pointwise.com.
Old   September 8, 2009, 09:17
John Chawner
Maddin:
Gridgen provides two approaches to dealing with CAD problems like those you describe. Fault Tolerant Meshing provides an approach where the CAD data is meshed as is and the grid is healed (merged) over the gaps. Solid Meshing gives you the ability to form the geometry into a solid that is computationally watertight. For more information, call us at 800-4PTWISE.
Old   September 8, 2009, 10:25
Would be an expensive call for me. Do you have some information online? Sometimes a tutorial where I can see how it works?
Old   September 8, 2009, 10:33
John Chawner
Maddin:
I don't recall off the top of my head whether any of the tutorials included with the software go into a lot of detail about Fault Tolerant Meshing. I'm fairly certain there's one about making solids. If those don't answer your particular questions, you can always email Support at support@pointwise.com.
ccm+, grid, gridgen, mesh
Importing gridgen mesh files into gambit/fluent Wee FLUENT 2 June 21, 2011 09:35
Mesh generation in Gridgen cfddummy Siemens 2 June 16, 2007 14:25
importing gridgen msh into fluent/gambit CH FLUENT 4 November 5, 2006 22:27
Problem in importing the Mesh fred Siemens 4 May 13, 2005 13:36
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
