November 18, 2024, 10:07 |
Surface repair problem
These are the first times on starccm, so forgive me if I have taken some things for granted. I have problems with the surface repair tool, I imported the fluid domain from solidworks in parasolid format. When I go to run the surface repair tool it finds me numerous problems and if I go to correct them it automatically eats a large part of the figure. How can I avoid this problem? I have tried importing the geometry in .stl format but doing so does not allow me to do a ‘split surface by patch’ to name the various surfaces.
I will be grateful if you can help me PROB.jpg PROB2.jpg |
Yesterday, 14:57 |
Rep Power: 16 |
This looks more like a problem of tesselation rather than actual errors in the surface. Try re-tesselating your part (select under parts => right click re-tesselate) and check again in surface error if the errors disappear.
If your CAD is clean, you should pass surface repair without major problems. Minor are ok and usually not a problem to the solver. |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 19:28 |
leading edge 3D surface mesh problem | Muggy | STAR-CCM+ | 1 | May 4, 2020 08:12 |
Fluent Fault-tolerant Meshing surface separate problem | PHabib | FLUENT | 0 | April 16, 2020 10:10 |
free surface problem with capillary effect | rabbitmelon | CFX | 25 | August 16, 2013 04:05 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 09:52 |
